Activity Forums DVD Authoring DVD size format???
  • DVD size format???
    Posted by Esther Casas on January 15, 2008 at 11:01 pm
    Hello everyone!!!
    I am importing a QT movie(preset to 720X480 NTSC/DV Widescreen 16:9 aspect ratio) into After Effects and after editing I like to burn the final movie into a DVD.
    I heard that most of the DVD final movs are made at 864X486, I also heard that it can be made at 720X480 size dimensions and I don’t need to switch to 864X486, is that correct? if I switch sizes I will lose image and that is bad… 🙁
    and what is the best program to put your QT into a DVD for final product to be seen in a widescreen? I heard it comes with FinalCut..but not sure where to get it.
    Thank you very much!
    Esther
    http://www.claymaniak.com
    Esther Casas replied 18 years, 7 months ago 2 Members · 2 Replies
  • Michael Sacci
    January 16, 2008 at 8:35 am
    NTSC video for DVD is 720×480. Still with that and make sure you use 1.2 aspect ratio (widescreen) in and out of AE.
    864X486 is what you use when making still picts with square pixels.
  • Esther Casas
    January 16, 2008 at 3:25 pm
    Hi Michael,
    Thank you for your quick answer.
    I will use 720X480 then, but is still ok if I have a mix of QTs and also some still pics (Widescreen 1:2)in between?
    Thanks a lot!!!
    Esther
    esther@claymaniak.com
