DVD-RW
Posted by Dan Sherman on January 17, 2006 at 3:53 amClient is supplying video on that dvd-rw shot with a Sony Handicam disc camcorder.
Can I capture that with my dvd player,—or will I need the camcorder to capture with firewire?
I do know that Vegas 6.0c is apparently set up to handle this media/format.
Anything special we need to know when weorking with these discs?Jeremy Rochefort replied 20 years, 8 months ago 3 Members · 8 Replies -
Jeremy Rochefort
January 17, 2006 at 6:51 am -
Edward Troxel
January 17, 2006 at 2:46 pm -
Dan Sherman
January 17, 2006 at 2:46 pmDid that Jeremy.
Window says no dsic available.
In fact the disc is in the machine.
Tried browsing to machine, but no luck,—just window with grayed out “OK”.
Maybe a preference we’re overlooking?
Thanks -
Dan Sherman
January 17, 2006 at 2:58 pmThanks Edward,—I appreciate that the quality would be better.
But I don’t have the camcorder only the disc.
And Vegas doesn’t see the disc in my DVD machine,—doesn’t recognize it.
Says “no disc available”. Like it’s not there,—but it is. -
Edward Troxel
January 17, 2006 at 3:00 pm -
Dan Sherman
January 17, 2006 at 3:27 pmI’ll have to find a camcorder then.
Will any camcorder do or must it be the one used to record this particular disc?I now understand what you mean by rednering to AVI once the raw asset is imported. Will do that.
Thanks. -
Edward Troxel
January 17, 2006 at 5:30 pm -
Jeremy Rochefort
January 18, 2006 at 8:00 amEdward has got a point about the disc not being finalised or similar. I must be honest and say I haven’t worked with dvd camcorder footage.
I quote form the Help file:
From the File menu, choose Import, and then choose DVD Camcorder Disc from the submenu. The Import DVD Camcorder Disc dialog is displayed.From the Source drop-down list, choose the disc that contains the video you want to import.
The Destination box displays the folder where the video will be imported. The folder name is based on the disc’s volume label.
Click the Browse button if you want to choose a different folder.
Click the OK button to start importing video.
After importing is complete, the video from the disc is added to the Project Media window.
You can then add the imported video to your project just like any other media file.
Cheers
Jeremy
MJ Productions
