Activity Forums Apple Final Cut Pro Legacy DVD Ripping Troubles
  • DVD Ripping Troubles
    Posted by Alec Gitelman on July 5, 2007 at 5:41 pm
    I am trying to get some footage from unprotected DVDs for working in FCP. I am copying the VOB files to my hard drive and converting them using Compressor to .mov . My problem is that the audio disappears. I can pipe the video through a deck and capture using firewire but would rather avoid that. Does anyone know what’s going on? I used to be able to rip DVDs, i also tried other soft on a pc which used to work for me before and still no luck.
    David Roth weiss replied 19 years, 2 months ago 3 Members · 5 Replies
  • Shane Ross
    July 5, 2007 at 5:47 pm
    #7 DVD into FCP
    Shane’s Stock Answer #7:
    To start, I will state that trying to capture any DVD you bought or rented, be it a Hollywood movie or exersize video, is illegal. I will not give you any tips on how to bypass copy protection. It is there for a reason.
    To capture footage from a DVD, you have a couple options.
    1) Route the DVD player to your DV camera or deck via the RCA cabling. Then you can put the footage you want ontp DV tape and have the benefit of timecode in case the need to recapture comes up.
    2) You can get a great application called DVDxDV (Google it). This opens up the DVD and allows you to convert the video to DV/NTSC footage. And it allows you to only convert what you want by allowing you to mark in and out points. The free version puts a big watermark across the center of your footage, but if you pay $25 for the standard version, that goes away.
    Or you can use Mpeg Stream clip. This is free.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Alec Gitelman
    July 5, 2007 at 5:59 pm
    Thanks, Shane. Will try.
    Question: is there any sense in trying to go for a better quality transfer from dvd, perhaps to dvcpro50? especially since i’ll have to recompress again and put the finished product on another dvd.
    p.s. dvd is legal.
  • David Roth weiss
    July 5, 2007 at 6:41 pm
    If you are adding graphics the answer is yes, if not DV is as good as your video will ever get.
    “No job is worth doing more than once…”
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Alec Gitelman
    July 5, 2007 at 7:10 pm
    great, thx.
    btw. do you know what field order i have to specify if i am converting from the dvd to dvcpro50 ntsc in mpeg streamclip?
  • David Roth weiss
    July 5, 2007 at 7:19 pm
    More than likely lower.
    David Roth Weiss
    Los Angeles
