DVD rendering choices
Posted by Michael Ledesma on April 9, 2013 at 12:37 pmI have a video I edited for my band and I want to render it for a dvd to give to agents but I have no idea what format to render it to so a booking agent can play it on a pc or a dvd player for his tv. Can anyone give me a clue? The original clips are mp4 files.
Thanks a lot.
MikeMichael Ledesma replied 13 years, 5 months ago 3 Members · 7 Replies -
Mike Kujbida
April 9, 2013 at 4:52 pmYou didn’t say if you’re using Pro or Movie Studio but, if you have a newer version of your software, the quickest and easiest method is to go “Tools – Burn Disc – DVD”. Stick a blank DVD in your burner and that’s all you have to do.
Michael Ledesma
April 9, 2013 at 5:13 pmI’m using Vegas Pro 10. You mean I don’t have to choose which output format? Like wmv, avi, etc… and all their selections?
Michael Ledesma
April 9, 2013 at 5:16 pmI’m using Vegas Pro 10. You mean I don’t have to choose which output format? Like wmv, avi, etc… and all their selections?
Problem is, I don’t have a burner so I have to put it on a jump drive and give it to someone else to burn it. What rendering format is best to use?
Michael Ledesma
April 9, 2013 at 5:39 pmLet me rephrase my question:
I am about to render a video I edited and would like to know which format to render to burn to a dvd. I have a youtube template I use for yt videos. But would like to render it to burn to dvd. Which format should I use? -
Edward Troxel
April 9, 2013 at 5:52 pmStandard DVDs are MPEG2 so you don’t “choose a format”. It’s already chosen for you.
Use MPEG2 for the video and AC3 for the audio. Adjust the MPEG2 bitrate to fit the length of video you have. You can look through my newsletters (link at the bottom) for more details or do a search here.
Mike Kujbida
April 9, 2013 at 6:13 pmDVD authoring in Vegas requires an MPEG-2 file for your video and an AC-3 file for your audio.
I hope that you have DVD Architect as these steps assume that you do.
Give both files the same name and render them (video and audio) to the same folder.
Render your video to MPEG-2 using the following steps.
If your video is not in widescreen mode, then use the “DVD Architect NTSC DV video stream” template, otherwise do as indicated.Once you have this template selected, click the Custom button and modify as show below (a custom CBR bitrate of 8,000,000). This is done to maximize quality in the finished product. This template can be saved for future use if desired.
Once your video is rendered, it’s time to do your audio as shown below.
Once this is done, create a new folder on your hard drive for the DVD files.
Now load up DVD Architect, go File – New – Single Movie. If it’s in widescreen mode, change the video format mode to reflect that.Follow the prompts to go to the folder where your newly rendered files are. Click on the video file and, as long as the audio has the same name, it will be automatically loaded.
Once this is done, you;ll be returned to the main screen.
Click Make DVD on this screen and then Prepare.
Click on the folder that you created earlier and your DVD files (inside of AUDIO_TS and VIDEO_TS folders) will be created in that folder.
Give this folder to your friend for burning purposes.I hope that wasn’t too confusing 🙂
Michael Ledesma
April 9, 2013 at 8:18 pmNo, it wasn’t, thank you so much! I don’t have dvd architect. I l’ll look for it and refer back to your great tut. Many thanks, Mike!
Mike Ledesma
BonJourneyny.com
