Activity › Forums › AJA Video Systems › DVD Recorder from Kona 3 card
Posted by Ryghermix on August 21, 2006 at 2:12 pmQuick question. I have a Kona 3 card coming out of my FCP. I wanted to burn my TC Dailies to a DVD for the producers review. I cannot figure out how to install a DVD Recorder since there is no component input in any recorder. How are you guys getting your video/audio from your Kona card into your DVD Recorder?
Ryghermix replied 20 years, 1 month ago 3 Members · 5 Replies -
Dan Brockett
August 21, 2006 at 3:16 pmHiya:
Composite out and RCA audio from K3 box to composite video in and audio in on DVD recorder. Pretty straight forward. No DVD recorders I have seen have component in except for professional models that are expensive.
Works great for us.
Dan
Providing value added material to all of your favorite DVDs
Ryghermix
August 21, 2006 at 4:24 pmHmm K3 box I do not have, only the sdi and aes spine from the card. I have it hooked up to a DV deck. Is there a way to convert those component cables down to S?
Walter Biscardi
August 21, 2006 at 4:44 pm[Ryghermix] “Hmm K3 box I do not have, only the sdi and aes spine from the card. I have it hooked up to a DV deck. Is there a way to convert those component cables down to S?”
Heckuva lot easier to just get the K3 box. I make DVD recordings all the time out of the K3 using the Composite video feed and RCA audio feeds. It’s only $300 or something like that.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Dan Brockett
August 21, 2006 at 6:22 pmI agree with Walter, unless you have a high end DVCAM deck like a DSR-1500 or above, the adaptors to convert everything to what you need would cost more than the K-Box. http://www.markertek.com has the K-box for $265.00. Buy it, you need it, trust us.
Love mine.
Dan
Ryghermix
August 21, 2006 at 7:17 pmThanks guys, I will do that. I took a look at the back of the k3, and that is what I need.
