Activity Forums Avid Media Composer dvd recorder for avid timeline
  • dvd recorder for avid timeline
    Posted by Chai_lerner on February 26, 2006 at 12:57 pm
    Hi,I’m looking for a dvd recorder that can work with the avid timeline (so I won’t need to do all the export stuff). just want to play the sequence and record it to the dvd (like online mpeg2 convertor). does anybody works with such tool? thanx
    Robh replied 20 years, 6 months ago 5 Members · 9 Replies
  • 9 Replies
  • Michael Phillips
    February 26, 2006 at 3:08 pm
    I use on all the time. A basic $300 Philips version, but there are a lot models on the market. Make sure it has the I/O you need, mine came with svideo, composite, component, and DV (FireWire).
  • Chai_lerner
    February 26, 2006 at 4:26 pm
    thanx michael. can you recommend on one of these models? I heard about the jvc sr-dvm70 which is 3 in 1 (minidv player+hd-160gb+dvd recorder) but the problem is that there are built-in menus (18 templates) that you have to choose from, and make a menu for your dvd. It doesn’t look pro at all. thanx again. Chai
  • William Busby
    February 26, 2006 at 10:00 pm
    I believe you’re going to find that no stand alone DVD recorder will give you “pro” looking pre-fab’d menus.
    Good luck,
    Bill
  • Michael Phillips
    February 27, 2006 at 12:42 am
    Only the Pioneer which I can’t recall the model number, also has SDI input and costs around $5K
  • Liam Stephens
    February 27, 2006 at 7:28 pm
    We are currently using a Samsung DVDr-120 out of a XpressPro with Mojo. It’s pretty easier play on the timeline and hit record on the DVD player. Does a feature length film well. Haven’t had any problems as yet.
    L
  • Robh
    February 27, 2006 at 9:52 pm
    I use the Sony RDR-HX900. It has an onboard hardrive. You can play your timeline right into the hardrive and then burn as many dvd’s as you like. Mine has a 160gb drive so I can store a lot. It is a great quick solution to get something out on a DVD. It is pricey, but works great.
    Hope this helps.
    Robert
  • Chai_lerner
    February 28, 2006 at 10:21 am
    thanx. can I use the dvd recorders you’ve mentioned only with firewire? I don’t have a mojo. another question is about the menus – do I have to choose from some built-in templates or put in a jpeq or having no menu?
    and last – do you know about a good place in N.Y. to buy these tools?
    thanx again. Chai
  • Liam Stephens
    February 28, 2006 at 6:31 pm
    We go straight out via S-video or composite, very basic. We usually don’t make a menu. If u want to do that stuff, DVD studio pro is very good for the basic menus, chapters etc. But u will have to do all he encoding…
  • Robh
    February 28, 2006 at 9:13 pm
    There are many choices for these. Here is a link that gives you information on a variety of DVD Recorders:
    https://hometheater.about.com/cs/toppicks/tp/aatpdvdrecorder.htm
    The one i have does have a firewire input. You can also send composite, component and svhs. I found mine on sale at Best Buys. Not sure if you have one there in NY. You can shop online and see if they do. That is what I did before I went to the store.
    Hope this helps.
    Robert
