Activity Forums Adobe Premiere Pro DVD Re-authoring
  • DVD Re-authoring
    Posted by Lynn French on July 27, 2013 at 2:26 pm
    I drug and dropped a DVD into my hard drive. Opened and re-edited it in Premiere Pro, and then burned a new DVD through Encore. Am I losing resolution by doing it this way? If so how can I accomplish the same without losing resolution.
    Tero Ahlfors replied 13 years, 1 month ago 3 Members · 2 Replies
  • John Pale
    July 27, 2013 at 3:52 pm
    Yes, you are losing quality,
    When you export your timeline you will have to re-encode to MPEG-2. So are taking a second hit of MPEG compression.
    Editing breaks the original GOP structure. No way around re-encoding, if that happens.
    I suppose its possible, if you edit precisely on GOP boundaries, and stitch the files together..there are some high end authoring utilities that can pull that off..but that’s a different animal than editing in an NLE like Premiere.
    The only way to avoid quality loss is to edit the original assets and not the DVD files.
  • Tero Ahlfors
    July 27, 2013 at 3:57 pm
    And that is why you should make and store masters.
