Activity Forums Broadcasting DVD-R recorder to buy?
  • DVD-R recorder to buy?
    Posted by Sam Lesante jr. on March 22, 2006 at 2:41 pm
    I’m wondering if there is a dvd recorder out there that has component inputs.
    I’ve only been able to find composite in with component out.
    If there are no component input dvd recorders out there, which would you suggest to get the best picture quality?
    Right now I’m using pioneer Elite DVR-7000. I’ve had it a couple of years, I used a dvd cleaner disc on it once already but it’s giving some signs of failure. Everyone once in a while, I’ll record something on it and it won’t finalize the disc or even play it. Is it more cost effective to get it fixed or buy a new unit?
    TIA
    Sam
    Joe Garvin replied 20 years, 6 months ago 3 Members · 4 Replies
  • Bouncing Account needs new email address
    March 22, 2006 at 3:49 pm
    Do I have a DVD recorder for YOU!!
    It records on DVD-R, DVD-RW,
    AND
    DVD+R, DVD+RW
    AND
    Audio CD (makes a great standard audio CD!)
    AND
    CD-V (video CD format)
    It will FINALIZE a newly-recorded DVD in under 90 SECONDS!!
    It records DVD’s at HQ (1-hour) SP (2-hour) LP (4-hour) and SLP (6-hour).
    And the image and audio quality is superb.
    (Even the SLP recordings are very “watchable” unlike other DVD burners I’ve used.)
    No component inputs, but it has S-Video (almost as good as Component. looks great) and FireWire for direct input from a DV source.
    I used mine constantly for months… no problems.
    This little gem can be found at (of all places) COSTCO, for the unbelieveable price of
    $169.00 (yes, under $170.)
    https://www.costco.ca/en-CA/Browse/Product.aspx?prodid=10289826&whse=&topnav=&cat=4477&hierPath=79*4477*
    Now, do you think you should service your old unit?
  • Joe Garvin
    March 22, 2006 at 5:45 pm
    I found that most of the Philips line of DVD recorders have Component inputs and out puts
    Model DVDR 615
    Except… All the Philips models are DVD+R
    No Problem
    I make my DVD on a DVD+RW
    ( Rewritable are great if you mess up the first recording just erase it and start over )
    Then take the VIDEO TS folder from the DVD+R and use Roxio Titanium Toast to burn a DVD-R
    Simple -Quick and very High Quality
    And the unit sells for about $170.00 at most department stores
    compared to over a $1000 for a prosumer DVD-R machines with component Inputs
    good luck
    Joe
  • Sam Lesante jr.
    March 22, 2006 at 9:03 pm
    Are these units standalone or are they something you have to install into a computer?
    Sam Jr.
  • Joe Garvin
    March 30, 2006 at 6:11 am
    These units are stand alone
    just like an old VHS recorder execpt it records in DVD
    You can even record your favorite TV shows
    They are great for a quick and easy DVD of your video projects
    Joe
