Activity › Forums › Adobe Premiere Pro › dvd quality crap how to burn correctly???????? Help i’m in premiere pro hell.
Posted by Stefan W on April 14, 2005 at 11:50 pmOk, so I rendered my project before burning to cd. Then I exported it to dvd and then burned it. I tried Twice, once at 7m crd and then at 4mb both high quality of course. However, each disc is crap with quality jerky and slow (transitions don’t work well either). I have no clue on what the problem is, nor do I wish to keep wasting dvd-r’s. My test video was only five minutes long and with the high powered computer I have there should be no problem.
How do I burn to dvd correctly??? Plus what is the best program to get for buiding intros, buttons, pictures and chapters on the Dvd when it first plays?
stefan
P.s. Thanks for the help on the last question steve!!
Mike Velte replied 21 years, 5 months ago 5 Members · 10 Replies -
Aanarav Sareen
April 15, 2005 at 12:31 amWe can only help you, if you can provide us with a little more info.
Computer specs?
Video details?
Video duration?
Transition and/or effects used.[stefan W] “Plus what is the best program to get for buiding intros, buttons, pictures and chapters on the Dvd when it first plays?”
Encore DVD does a great job
Stefan W
April 15, 2005 at 2:26 amI’m not sure on the computer specs…something like 1gig ram, big harddrive. Anyways, it’s not the computer because quality is fine with video studio.
The video i made was vary basic just testing features in premiere, fiv min or so. I used some transition effect, text effecs and picture in picture. I tried burning the dvd just as it says in help. However, you see distortion and lines after completing the burn and playing it on the tv.
Tom Maloney
April 15, 2005 at 11:10 amJust cause one program works on a computer doesn’t mean Premiere will. Right off the bat, 1 gig of ram, should have more. Do you have different hard drives for system and video files ?
The best program you ask for creating dvds ? A lot of good ones, seems logical to use encore if using Premier.
I use Premiere with Encore and build nice dvds. Are you capturing lower fields first in Premiere ?
Mike Velte
April 15, 2005 at 11:49 amWhat are the properties of your source video? What are your Project settings? I suspect they dont match.
Stefan W
April 15, 2005 at 11:55 amSo you think my system is not powerful enough? I have to admit that i’m new at this whole thing and have no idea what” capturing in lower fields means”. Does that refer to how i’m placing video into the Timeline? EX. whether I’ve placed video in video track 2 first over video track 3??
Note: I’ve watched the video again and the only areas where distoration and lines appear is during transitions or video effects. For example, fast foward, reverse mode,”twirl in”,”slide in” and “zoom” with the picture sized smaller. Again, the video quality is good in all sections with no effect alterations. However, soon as say I slow the video down by 50%, distortion and lines appear on the screen.
Please help otherwise I have to go back to videostudio, which is to basic. I have 9 tapes to edit and I really need the functions of premiere especially its “razor” tool and “picture in picture” abilities.
Stefan W
April 15, 2005 at 12:12 pmsource video (I right clicked on the video in the timeline)
Type Avi movie
file size: 52.8mb
image size 720×480
pixel depth:32
frame rate: 29.97
source audio format: 48000hz-16bit stereo
conform audio format: 48000hz-32bi floating point-stereo
average data rate: 3.6mb/second
pixel apsect ratio: 0.9Project settings (out of the project menu)
dv playback
Timebase: 29.97 frames/second
frame size: 720×480
Pixel aspect ratio: d1/dv ntsc (0.9)
fields: lower field first
Display format – 30 fps drop-frame timecode
Title safte are 20 20
action safe area 10 10Audio sample rate 48000
display format;Did I list the correct settings? What should the correct settings be?
Mike Velte
April 15, 2005 at 8:57 pmType Avi movie
file size: 52.8mb
image size 720×480
pixel depth:32
frame rate: 29.97
pixel apsect ratio: 0.9Getting closer, I think…
What codec is you source video?? 52.8 MB is about 15 seconds?? 32 bit indicates it is uncompressed, but very low quality (3.6 mbs). How was this video clip created…export settings?? -
Stefan W
April 16, 2005 at 1:37 amUnder the project settings/video rendering tabs, the compressor just says DV(NTSC). I cannot hit the configure button next to it to select another codec.
Premiere Pro help says:
Note: If you use a clip in your video program without applying effects or changing frame or time characteristics, Adobe Premiere Pro uses the clip’s original codec for playback. If you make changes that require recalculation of each frame, Adobe Premiere Pro applies the codec that you choose here.Preset:
NTSC progressive 4×3 high Quality 7mb CBR 1 Pass ( I did it at 4mb too)
Comment high quality, CBR transcoding of Progressive frame content.video Summary:
Codec: MainConcept MPEG Video
Quality: 5.0 (high quality)
TV Standard: NTSC
Frame Rate: 29.97 drop Frame
Field Order: None (progressive)
Aspect RAtio 4:3
Frame Width [pixels}: 480
Bitrate Encoding: CBR
Bitrate {Mbps} 70000 ( high Quality)
M Frames: 3
N Frames: 15Encoding:
Export Range: Entire Sequence
Fields: none
Maximize Bitrate: no
Force Variable Bitrate: noDo you see any problems? You mentioned the video quality being uncompressed yet low quality. What does this 3.6mbs mean?
Thanks for all your help!!!!
stefan
Mike Velte
April 16, 2005 at 11:26 amA bit confused…you said 5 minute test video…and then 58 MB??
Also try changing the Field Order to Lower.
