Activity Forums VEGAS Pro DVD Pro 4.5 problems
  • DVD Pro 4.5 problems
    Posted by Jim Oldebeken on September 11, 2007 at 12:05 am
    Two quick initial “challenges” in using DVD4.5
    When I attempted to import a mpeg-2 file created in Vegas 6, I received an error message “The plug-in needed to read the file is not registered. You can click the Register button to register a plug-in that will read this file.” I was able to import an AVI file
    When I attempted to prepare the DVD (AVI files in the project, one from Vegas 6 and another from Vegas 8), I got the message “Warning: An error occured while writing a file. The requested plug-in does not have thenecessary features unlocked.”
    Any ideas?
    Jim
    Reach Video
    Jim Oldebeken replied 18 years, 11 months ago 2 Members · 2 Replies
  • Edward Troxel
    September 11, 2007 at 12:12 pm
    Is DVD A 4.5 registered? Registering DVD A will register the MPEG encoder/decoder automatically.
    Are you running the demo mode of DVD A 4.5? If not, you may need to contact tech support or simply reinstall and reregister to see if that fixes things.
    Edward Troxel
    JETDV Scripts
  • Jim Oldebeken
    September 11, 2007 at 5:40 pm
    Edward,
    Thanks very much for responding. Actually both are registered. Will take your advice to uninstall and try again.
    I did review one render using V8. A clear improvement in color and even type (built with the old text generator).
    One issue I found was some bright colors were blown out of a motion background creating a solid color. Happened two times. Gotta figure that one out! Tech support said that sometimes the 32 bit floating point needs to be turned off.
    Have a super day.
    Jim
