Activity Forums Compression Techniques DVD player won’t play
  • DVD player won’t play
    Posted by David Benassi on May 19, 2009 at 4:30 pm
    Just burned my project onto a DVD 5, with highest bit rate compression. My dvd player is about 5/6 years old, so I’m sure I can’t handle it. Just wondering if there is a general bit rate used in the industry that is sure to play on most standard players?
    Daniel Low replied 17 years, 3 months ago 3 Members · 2 Replies
  • Craig Seeman
    May 19, 2009 at 4:28 pm
    It’s hard to pin an exact number. The range seems to be peaks of 6.5 to 7.5. I take the more cautious road generally. The spec is 9.9 but that just goes to show how unrealistic a spec can be.
    BTW I’ve seen cases where some encoders overshoot the peak so there’s always some risk.
  • Daniel Low
    May 19, 2009 at 6:04 pm
    Yes, a true 7.0 CBR plus audio plays on everything I’ve come across. Bear in mind that this is still a very high datarate and should only be needed for most demanding types of content.
    Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004
