Activity › Forums › Apple Final Cut Pro Legacy › DVD player or quicktime problem
  • DVD player or quicktime problem
    Posted by George Bonilla on September 11, 2006 at 10:39 pm
    I am burning DVD’s from my quicktime file. It is doing something strange. It drops these lines of dialogue in the same spot on each disk. But on another player those lines are fine. How will i know which player it will play on? Can I fix this problem? I re-laid in the lines and burned a new quicktime. I re-mixed down the audio. It just happens on this one DVD player? Thoughts?
    Jeremy Garchow replied 20 years ago 2 Members · 1 Reply
  • Jeremy Garchow
    September 12, 2006 at 12:41 am
    How did you compress the files for DVD, Compressor? If so, check out the aiff or ac3 file that compressor created and see if the dialogue is there, if it is it’s the DVD player, if it’s not it’s a bad encode. If it’s a bad encode, delete all of audio render files and try again.
    Jeremy
