Activity Forums Apple Final Cut Pro Legacy DVD playback
  • Posted by James Haefner on August 7, 2008 at 1:47 pm
    Hello COWS:
    I am seeing and hearing on my DVD playback glitches.
    At first I thought it was my timeline/project, but its not. I noticed after different tries through the DVD the glitches come and go.
    I just want to make a CLEAN DVD MASTER and do not fell comfortable with the playback yet. What can I do to make this playback clean.
    method export > Export QT Movie > Save as Disk Image > Disk Utility Burn with a MAC G4 laptop.
    Searched through FAQs. Exhausted various versions and improvements.
    James Haefner replied 18 years, 1 month ago 2 Members · 2 Replies
  • Jerry Hofmann
    August 7, 2008 at 2:00 pm
    The best way to create a DVD in Studio is to select the sequence, then choose file/export/using compressor. If your sequence is shorter than an hour, use a CBR setting of about 6.8 or so, and let the system chug away. This will take longer than your method, but it’s better quality.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • James Haefner
    August 7, 2008 at 3:04 pm
    hey Jerry:
    unfortunately I am working with FCP 5. I-Movie DVD authoring > Save as Disk Image > Disk Utility
    Not Final Cut Studio.
    Any other suggestions much appreciated.
