Activity › Forums › DVD Authoring › DVD playback stops/ gets stuck arbitrarily…
  • DVD playback stops/ gets stuck arbitrarily…
    Posted by Rajnesh Domalpalli on May 25, 2006 at 4:01 pm
    Hi All,
    When I try playing back my DVD either on my Apple G4 Powerbook or a DVD Player, I find that the DVD gets stuck at a certain point, and the only way is to continue, is to remove it from the system, then try using the Scene Index to get in at a different point. No 2 DVD’s stop at the same place.
    I made this DVD from a 1Hr 51Min film, on a Dual Layer Verbatim DVD+R disk on my G5, using DVD Studio Pro. I created the Mpeg-2using Sorenson Squeeze Version 4.3, and used Stereo Audio compressed to AC-3.
    Since this was a feature, I had 6 Reels – each with its own Video and Audio that I imported into DVD SP.
    In Sorenson Squeeze, I used a bit rate of 6.5Mbps and 2Pass VBR. I used 23.98 Fps (since the DVD standard says, palyers will accept it, and add pulldown on playback?).
    Any help would be greatly appreciated. Thanks in advance for your replies.
    Regards,
    Rajnesh
    Rajnesh Domalpalli replied 20 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
