Activity Forums DVD Authoring DVD Playback on PC versus Mac
  • DVD Playback on PC versus Mac
    Posted by Davis Draheim on July 21, 2005 at 8:48 pm
    I have a Pioneer DVD Recorder PRV-9000. I have it hooked up to my camera to record in real time. It records with a bit rate of 9.29 Mbps. Now, after I finalize the DVD, I can play it in any regular consumer DVD Player. I can play it in my G5. I cannot play it back properly in my PC running either XP or 2000. I have updated my DVD player and the decoders on the PC. I can get it to play after some time of loading, but everytime the scene changes dramatically or I change the chapter the computer or DVD seems to freeze for quite some time.
    I am wondering if this a a RAM or Proccessor Speed problem vs. a DVD problem.
    Any thoughts?
    Davis
    Daniel_l replied 21 years, 1 month ago 4 Members · 3 Replies
  • Jason Casey
    July 22, 2005 at 4:17 pm
    9.29 Mbps……This is the problem!
  • Chris Borjis
    July 22, 2005 at 4:27 pm
    Get your bitrate down to around 5-6.
    use dolby for audio not L-PCM (if you are)
    make sure your using good quality media.
    that should clear it up.
  • Daniel_l
    July 26, 2005 at 10:15 pm
    The standard calls for a video datarate of no higher than 9.8Mbps for video only. I bet my Philips 963SA could play it.
    Windows can’t play DVD’s ‘out of the box’ unless you have a 3rd party decoder installed and they vary in quality/capability vastly (or should that be Vista-ly)
