Activity Forums Apple Final Cut Pro Legacy DVD playback not smooth
  • DVD playback not smooth
    Posted by Putopian Vohra on January 24, 2012 at 11:02 am
    Hi all
    I am totally a beginner in video editing. Don’t know much about technical aspects and video formats.
    I am here to solve a issue. I worked on a project (720 x 576) and exported using DVD Studio Pro. The DVD is not playing smoothly. The problem is more visible during camera pans and fast actions. The tape was Sony BetaCam and was captured to SD.
    Can anyone help?
    Putopian
    Putopian Vohra replied 14 years, 7 months ago 3 Members · 4 Replies
  • Mark Suszko
    January 24, 2012 at 10:55 pm
    Check your field order. Is final version progressive?
  • Putopian Vohra
    January 25, 2012 at 4:18 am
    Thanks for your interest in this issue.
    No, it’s not progressive. I gave the default DV PAL settings. It is interlaced; lower field first. Is it wrong?
  • Rafael Amador
    January 25, 2012 at 9:17 am
    That some times happens with some players when you have set a too high data rate.
    Which are your compression setting and where are you playing the DVDs?
    How long is the program?
    rafael
    http://www.nagavideo.com
  • Putopian Vohra
    January 25, 2012 at 10:45 am
    I compressed the video in DV Pal(Default settings)
    The duration of the project is around 40 mins.
    But today, when I tried a small clip with Apple Pro HQ setting, it is working fine. Will check if it is the issue.
