Activity Forums Adobe Encore DVD DVD Playback freezes
  • DVD Playback freezes
    Posted by Jeff Marier on February 18, 2010 at 6:08 pm
    okay, I have a 67 minute DVD with about 17 chapters. Around chapter 14 it starts freezing, read below to see what I’m running and what I’ve tried:
    First I edited it in premiere elements 4.0 and tried to burn it from there.
    Then I exported as a DV AVI file and tried to burn it from Encore at both 8x and 4x speeds (4x was the lowest allowable)
    Then I tried to just create the Video TS file and burn it through Nero
    Then I lowered the bitrate to 7.0
    Then I changed it to CBR @ 7.0
    With every change I made the problem was still the same.
    Finally I burned it from elements again at 5.9mbps with just a few artifacts, but the quality has suffered a smidge.
    Any ideas why I would have to lower the bitrate so much for a 67 minute dvd?
    I am running a single processor (p4, 3.14), 1.5 RAM.
    Adobe Encore Version 1.5
    Taiyo Yuden Discs
    Thanks in advance….(never had this problem before)
    Jeff Marier replied 16 years, 7 months ago 2 Members · 2 Replies
  • Nicole Haddock
    February 24, 2010 at 8:53 pm
    I never burn above 6.5mbps when it comes to SD DVDs. Playback CAN become an issue. How are you encoding the audio?
  • Jeff Marier
    February 25, 2010 at 3:22 am
    My final DVD was burned from elements, so whatever the default setting is I don’t know (you can’t change that parameter, only the mbps)
    With Encore I used the default setting originally, then changed it to PCM.
    Would audio issues cause video to freeze?
