Activity Forums Apple Final Cut Pro Legacy DVD Output Quality
  • DVD Output Quality
    Posted by Mark Fanjoy on January 16, 2011 at 12:50 pm
    I have tried every different setting I can come up with in FC and Compressor and cannot create an SD DVD that looks reasonable. The quality is just terrible considering the original source. I am hopeful someone can scan this flow and point me in the right direction.
    Original Source: Canon HF-M31, 1920-1080, 30fps in AVCHD format
    I use Log & Transfer to ingest and convert to Apple ProRes 422HQ. The timeline settings appear as such:
    I then export using Quicktime Conversion using these settings:
    I then process that QT file through Compressor using these settings:
    From beautiful original footage, I end up with what equates to 2nd generation-looking VHS.
    FYI: I tried exporting from FC a stand-alone QT file with original source settings. Then used the Compressor settings above. But the output result was even worse.
    Thank you in advance for any advise/direction!
    Mark Fanjoy
    Wherever I am…I’m lost!
    Paul Jay replied 15 years, 7 months ago 8 Members · 11 Replies
  • 11 Replies
  • Jerry Hofmann
    January 16, 2011 at 1:17 pm
    Try skipping the QT conversion. Instead, just compress to MPEG-2 directly from the ProRes HQ sequence. Theory also states that you should send directly from FCP to Compressor an UN rendered sequence. Saves a generational loss of those clips. Also…
    If your sequence is shorter than say around an hour. Change the Compression quality setting to be a CBR (Constant bit rate) at around 7 MBits.. Renders faster, and doesn’t ever lower that bit rate.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Ian Brown
    January 16, 2011 at 1:44 pm
    The main thing you appear to be doing wrong is you are using QuickTime CONVERSION.
    You never use this for DVDs. . . . . it’s mainly for internet videos.
    In FCP select File>Export>QuickTime MOVIE.
    Leave everything in the default settings and click Save.
    Drop the resulting file into Compressor, select an appropriate DVD preset together with the Dolby Digital audio one and click submit.
    When encoded, drop these 2 files into DVD Studio Pro and burn.
    Result . . . . . perfect DVD.
  • Ian Brown
    January 16, 2011 at 1:50 pm
    In Compressor I would, ideally, suggest making your own preset as Jerry suggests.
  • Mark Fanjoy
    January 16, 2011 at 2:14 pm
    Thanks, gentlemen. Ian, I did EXACTLY that, but my compression from FC version actually looked better. Go figure.
    Jerry, I may need a little more detail to understand your language…
    Are you saying do what Ian described and output a standalone QT file with existing timeline settings, then take that file to Compressor?
    Mark Fanjoy
  • Ian Brown
    January 16, 2011 at 2:19 pm
    You must be doing something wrong somewhere (that you have not mentioned) as what I described will always produce excellent results. It’s the standard method.
  • Chris Tompkins
    January 16, 2011 at 3:28 pm
    Ya, turn on Frame Control in Compressor too.
    Chris Tompkins
    Video Atlanta LLC
  • Larry Asbell
    January 16, 2011 at 3:59 pm
    Doesn’t turning on frame controls merely unlock those settings? What setting would you change once they are unlocked?
  • David Roth weiss
    January 16, 2011 at 4:46 pm
    [Larry Asbell] “Doesn’t turning on frame controls merely unlock those settings?”
    No, it actually turns on several automatic features of Frame Controls. Check it out in the manual sometime, it makes for an interesting read.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Ernie Santella
    January 16, 2011 at 5:09 pm
    Here’s some tutorial help on settings and audio.
    https://www.kenstone.net/fcp_homepage/compressor2_custom_presets.html
  • Jerry Hofmann
    January 16, 2011 at 5:40 pm
    It’s pretty easy… just select the sequence, then choose file/send to/compressor. Use any of the DVD best quality presets, then change the quality settings to be CBR (constant bit rate), and 7 mpbs as the data rate. Leave the audio settings alone.
    Jerry
    Current DVD:
