Activity › Forums › Adobe Encore DVD › DVD Menu Challenge
DVD Menu Challenge
Posted by Carlos Sanchez on January 22, 2008 at 9:33 pmHi, I been trying to recreate a DVD menu I saw on youtube. However Encore CS3, shows me some red boxes because the buttons are too close to each other and also because i made the writting on the bottom as a (=1) highlite for every button. The writting will show something different each time a picture is highlited. Can any of you brave experts help me please.
Here is the link to what the menu looks like
https://www.youtube.com/watch?v=riussf7LW7g
Thanx
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Sonali Gulati replied 17 years, 4 months ago 6 Members · 19 Replies -
John Rich
January 23, 2008 at 3:17 pmOne way to do it might be to make eight different menus and use auto-activate to connect them. Check out a tutorial by Dave Garrett (google “Doogs” ) called “full color subpicture highlights” under the Encore 1.5 section, for a nice discussion.
I never used the second menu that Dave uses here for the “activated” state” and it seems to work ok.John
JOHNR
All-missouri
January 23, 2008 at 6:57 pmThe red boxes that are showing up are because the buttons are too close together, as you know. I way to get around this is to not include the entire snapshot as a button. What might be the best way to keep most of the picture in the button “area” is to create an “empty” layer for each button in Photoshop and not include the actual polaroid in the layer set. With the “empty” layer, create a box and set the fill to zero. In Encore, resize that layer to take up how big you want the actual clickable area for the button to be. If you have problems understanding this let me know and I should be able to send you a PSD that shows the technique a little bit more.
All-missouri
January 23, 2008 at 7:29 pmNevermind most of what I said in that post. Take the white part of the polaroid out of the layerset though. Leave the layer that takes the video and the highlight. That should make the button small enough so that it doesn’t interfere with it’s neighbors.
Carlos Sanchez
January 24, 2008 at 2:06 amI appreciate your help, would you be able to send me that psd, please.
Thanx alot
All-missouri
January 24, 2008 at 3:10 amhttps://www.freewebs.com/pilotdvd/Polaroid%5FMenu.psd
Hopefully clicking on that will let you download a sample I did pretty quickly. Hopefully that gives you some guidance.
Carlos Sanchez
January 24, 2008 at 11:37 pmStill doesn’t work, what I am most interested in is when highliting a button the text will appear on the bottom left corner with a title of what the polaroid is. See link for an example menu, check towards the end were you hoover the mouse over a polaroid text appears down below in the bottom left corner and the text in the polaroid disapears, i now how to make it disapear, but i need help in making the other text appear. I watch the tutorail and have tried the psd file but i am still strugling. please help
Thank you
All-missouri
January 25, 2008 at 1:22 amOkay, I wasn’t quite sure which aspect you were going for, but now that I know.. here’s what you do.
As John pointed out, the best approach is to create a separate menu for each button that is selected. For instance, if you have 8 polaroids, then you will have 8 menus.
In each menu, the text in the lower left will not be in any layer sets and it will reflect which button is selected.
Also on each buttons menu, set it up so that it will have a moving video in the picture while the others are all stills. -
George Wing
January 25, 2008 at 5:59 am[carlos sanchez] “See link for an example menu, check towards the end were you hoover the mouse over a polaroid text appears down below in the bottom left corner and the text in the polaroid disapears”
If you are using auto-activate buttons to do a “switched menu” technique, then don’t hover your mouse pointer over a button. Use the navigational arrows instead (up/down/left/right).
Regards,
George -
John Rich
January 25, 2008 at 4:23 pmI was just messing around with this, and to me it appears that one cannot have a video button on either side of the menu with the ” selected button” as the button link has to go to another menu with autoactivate selected. However, if you have eight buttons, then 6 of them could have button motion.
YOu might be able to get around this, by creating short clips of your destination movie for the two contiguous buttons, and then shrinking them in Preiere or AE and using this as a motion background. I think I’ll put this together as a screen capture, and if you want to see it let me know.
JohnJOHNR
