Activity Forums DVD Authoring DVD Language
  • DVD Language
    Posted by Salvo on July 5, 2005 at 11:02 pm
    Hello there;
    I Use DVD STudio Pro 3.0,
    I have the simplest problem, I need to author a DVD tha contains two audio streams and on video track, I need to make the DVD capable of switching the audio tracks (only) via the audio button found in most common DVD remotes.
    Since I am knew to authoring, I am seeking your help in order to avoid frustration with the manual which is extremely confusing.
    Could anyone help;
    Thank you very much
    Arnie Schlissel replied 21 years, 1 month ago 2 Members · 1 Reply
  • Arnie Schlissel
    July 6, 2005 at 6:08 pm
    Don’t know what to tell you. If you want your hand held step by step, read the manual & do the tutorials. If you want someone to do the work for you, pay an experienced DVD author.
    You could also see if there are any classes or workshops on DVD authoring being offered in your area, or perhaps you could hire an experienced author as a tutor.
    Arnie
    https://www.arniepix.com
