Activity Forums DVD Authoring DVD-Lab PRO 2.0 Released
  • DVD-Lab PRO 2.0 Released
    Posted by George Wing on July 27, 2006 at 10:56 am
    DVD-Lab PRO 2.0 has been released!
    I believe the list of features, combined with a clean interface and extremely low/reasonable price, makes the “PRO” version one of the most advanced SD DVD Authoring packages for the PC.
    A comparison chart for the different levels of DVDLab:
    https://www.mediachance.com/dvdlab/comparison.html
    Here are some of the new features in DVD-Lab PRO 2.0
    – More compatible slideshow – in full GOP instead of I-frame
    – Mega-Project with disk caching – this will cache data during designing into disk which will allow user to create project with huge amount of menus without windows crying for memory. With Mega-Project you can now create up to 640 menus per VTS!
    – Each menu can have up to 30 cells inside where each cell can have its own set of buttons and other parameters.
    – Smart Compile will recompile only the changed menu parts and keep the video vobs from previous compile. This way you can recompile menu changes within a minute!
    – Multi-PGC title. The Segment Title has been now redone to a full Multi-PGC title. (Each segment in a Multi-PGC Title can now have its own pre and post commands)
    – Audio Title can show new slide on each mark
    – Pre and Post verificaton log
    – Multiple Angles
    – Buttons on Movies (Each chapter can have different buttons)
    – Faster transition encoding
    – native 24p support (Note: this is not 23.97 with pulldown)
    – Simpler to use and more robust audio transcoder – can transcode any audo file for which you have codec
    – Subviews in Conections – place certain project objects to a freely definable subview (up to 9 subviews) so you can work with them separate from the main
    George Wing replied 20 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
