Activity › Forums › DVD Authoring › DVD is Toast
  • DVD is Toast
    Posted by Cybele Sunday on June 30, 2006 at 2:33 pm
    I am an Avid Editor and somewhat new to making DVD media…
    I have an brand new iMac at home and I have Toast Titanium which I like because it is simple. At work I am on an Avid Adrenaline with an HP xw8000 CPU. Last night I made a DVD on toast. I used a Quicktime reference which I made into a MPEG2 (sent through Flipfactory).
    When I saw the finished DVD- the colors were horrible. The color was completely off or non-existant and there was terrible artifacting.
    So, what is the best kind of file would you say to make a DVD in Toast?
    Size, compression, etc.
    Thanks!!!!!!
    Note-
    I also have Sorenson Squeeze installed at work for compressing files.
    work is the curse of the drinking class.
    o wilde
    Noah Kadner replied 20 years, 3 months ago 2 Members · 6 Replies
  • Noah Kadner
    June 30, 2006 at 4:46 pm
    If you’re on Mac- Toast is at the bottom of the list for good DVDs. Try iDVD or better DVDSP and spent some time with the tutorials. Great looking DVDs are not made instantly.
    Noah
  • Cybele Sunday
    June 30, 2006 at 7:00 pm
    Thanks. I have iDVD….
    What kind of file would work best for that?
    Uncompressed Quicktime?
    Any other input on export settings from Avid, etc?
    What makes it better?
    I do not care about Menu’s etc for this.
    Thanks.
    o wilde
  • Noah Kadner
    June 30, 2006 at 8:29 pm
    Chances are you probably compressed it twice because Toast does it’s own re-encoding. Best to give iDVD an Uncompressed 8-bit QuickTime. And remeber DVD is 720×480 not 486 as some flavors of Avid like.
    Noah
  • Cybele Sunday
    June 30, 2006 at 9:55 pm
    Thank you. I will try it in iDVD.
    Best
    o wilde
  • Cybele Sunday
    June 30, 2006 at 9:59 pm
    Would you recommend exporting it RGB or 601 for video levels?
    o wilde
  • Noah Kadner
    July 1, 2006 at 12:58 am
    I’d try both but I believe 601 is correct.
    Noah
