Activity Forums DVD Authoring DVD: HD to SD in Final Cut – change sequence settings first?
  • DVD: HD to SD in Final Cut – change sequence settings first?
    Posted by Daniel Gauthier on November 17, 2008 at 7:24 am
    I have edited a feature-length animated film. The sequences settings are 720p, 29.97fps, animation codec. To encode the highest quality SD DVD should I export to compressor directly from the HD timeline, or copy the film into a SD timeline and export from that? Has anyone done this & is there any noticeable difference in final output?
    Daniel Gauthier replied 17 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
