Activity Forums Apple Final Cut Pro Legacy DVD from P2 Footage Just Shot
  • DVD from P2 Footage Just Shot
    Posted by Daniel Elder on January 17, 2008 at 8:25 pm
    I wanted to find out if their is a quick way to make DVD’s of all the footage I just shot without having to capture everything then transfer it to DVD? Also without Proxy Board. I am using the HVX200 in this case, we also use the HPX2000 with the Proxy board, which is a great solution for quick DVD’s.
    Oh, and a bit more information. We are working off 16 GB cards and can’t really burn them to Blu-Ray discs, so what is the most efficient option at this point?
    Daniel Elder
    producer
    http://www.luminair.com
    Tom Brooks replied 18 years, 7 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    January 18, 2008 at 1:44 am
    No direct MXF to DVD device I know of.
    Hot ticket in digital backup is likely to become a tape drive. Look at the latest of these. LTO drives seem to be the best bet.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Daniel Elder
    January 18, 2008 at 9:42 pm
    Thanks, I’ve been looking into those for sure, just wish there was an app for straight to DVD, hmmm.
    D
    Daniel Elder
    producer
  • Tom Brooks
    January 19, 2008 at 2:21 pm
    Exabyte has a FW800 external tape backup device that some folks have pointed to. It’s about $1200–cheap. Trouble is, it’s pretty slow. I believe the transfer rate is 6MB per second. That sounds like about 44 minutes per 16GB card. Ugh. The cartridges are not entirely cheap either.
    Jan Crittendon Livingston from Panasonic, has mentioned using a RAID-1 removable drive setup. The idea being you backup to two hard drives at once and then swap out the drives and store them when they’re full. One hard drive sitting on the shelf seems awfully risky–two is safer. Wiebetech has a really cool trayless removable drive system that would be a dream for this kind of thing. What do you think of this?
    https://www.wiebetech.com/products/RTX200.php#pricingavailability
