Activity Forums Apple Final Cut Pro Legacy DVD framerate issues
  • DVD framerate issues
    Posted by Samuel Grund on July 15, 2008 at 8:45 pm
    This is driving me nuts..
    I’ve edited video from two different cameras (one was mine and the other I borrowed from a friend) in FCP 5 and exported with just “Export > Quicktime Movie…” which I then burned to DVD using iDVD (I don’t have DVD Studio yet). When I play the dvd, footage from one camera (mine Cannon ZR300) looks fine but when it switches to the other camera (friends – a sony hard drive camcorder) the video looks horrible. I think it looks like the frame rate is too slow. This issue only happens when playing the video on commercial dvd players, the video looks fine when played via apple’s DVD player software and VLC.
    I’ve never had this happen before and I’m lost. Anyone have an idea what I should do? Thanks.
    Samuel Grund replied 18 years, 2 months ago 2 Members · 2 Replies
  • Michael Gissing
    July 15, 2008 at 10:49 pm
    My guess is that when you watch the DVD on a commercial machine, you are watching it for the first time on an interlaced monitor. The problem may go back to the field dominance settings in the original FCP sequence. If you have not watched the project on an interlace monitor while editing, you won’t have picked up any field problems as computer monitors are progressive. Same is true of watching the DVD on the computer.
    If the “horrible” image is all jittery then that’s my best guess.
  • Samuel Grund
    July 16, 2008 at 9:23 pm
    Yeah I’ve used similar camcorders before. The best results I’ve gotten were to import video and audio separately.
    I did figure out my problem after trying a few different things. I figured my problem was the MPEG-2 encoding and I simply put the film in MPEG-2 using VisualHub before I burned it. Appears iDVD’s encoder was messing up my work. Thank you though! 🙂
