Activity › Forums › DVD Authoring › DVD format & compatibility issues
  • DVD format & compatibility issues
    Posted by Mitch Spicer on November 26, 2009 at 2:10 am
    I noticed there are other forums on here that deal with similiar issues, but I would like to know WHY professional movies work on virtually ALL DVD-players, and if I could personally get this type of disc and/or burner. When I put a professional DVD (meaning Titanic, or the Comebacks, etc.) in my PS3, it reads it as a DVD-RAM disc, does this mean I should purphase DVD-RAM discs? For jobs in the past, I have used various DVD-R disc types, such as Memorex or Verbatim (which im just trying out), and many sells have been returned for solution. Luckily I had DVD+R dics available, and made a new copy and that solved the problem, but I would like a better, more permanent solution. PLEASE HELP! I have more jobs coming up soon! 🙂
    Mitch Spicer
    ~WRS Productions~
    Michael Sacci replied 16 years, 10 months ago 2 Members · 3 Replies
  • Michael Sacci
    November 26, 2009 at 6:28 am
    All retail titles are replicated, stamped copies and that is one major step, orders pretty much start at about 1000 copies and run under $1k with complete packaging.
    Video bitrate should always be under 7.5Mbps (7Mbps max if you use VBR) and the audio should be encoded as ac3. DVD-R should be used, top quality disc only, I use Maxell plus but others have great success with other brands.
    The main reason for problems is bitrate and uncompressed audio.
  • Mitch Spicer
    December 3, 2009 at 8:13 pm
    Alright, thanks. And also, what about the DVD-RAM? Is that a disc type that is able for purchase and such, because that is what all professional DVDs are, like I said, Titanic, or the Combacks… every disc is DVD-RAM, what does that mean?
    Mitch Spicer
    ~WRS Productions~
  • Michael Sacci
    December 3, 2009 at 8:41 pm
    they are replicated disc, what you want are DVD-R (for DVD-5) and DVD+R DL (for DVD-9, dual layer) don’t worry about anything else.
