Activity Forums Broadcasting DVD footage good for broadcasting !!?? Help !
  • DVD footage good for broadcasting !!?? Help !
    Posted by Riccardo Vitale on February 22, 2008 at 8:32 pm
    We are shooting a documentary in Colombia using PAL equipment. A local TV has given us a bunch of vital archive footage in DVD format. These material was shot with NTSC, 3CCDs, cameras on MiniDVs and Hi8- and later transferred to DVD via firewire.
    Now we have a dilemma.
    Will it be a problem to copy these footage onto MiniDVs, capture it and then do the editing in FCP in the same timeline with our PAL material ?
    And, most important: Is there any loss of quality when going from MiniDV to DVD and back to MiniDV via firewire !?
    The final product has to be of broadcast quality. Potentially we have the option to acquire MiniDvs copies of these material. However this would notably increase production costs, so we hope we can use the DVDs.
    Any advice would be greatly, greatly appreciated !!
    Best regards
    Riccardo
    Dr Riccardo Vitale
    Anthropologist/Filmmaker
    Riccardo Vitale replied 18 years, 5 months ago 3 Members · 6 Replies
  • Bouncing Account needs new email address
    February 23, 2008 at 8:50 pm
    [Riccardo Vitale] “And, most important: Is there any loss of quality when going from MiniDV to DVD and back to MiniDV via firewire !?
    You don’t need to go to miniDV to edit DVD footage in FCP.
    You can put the DVD into the Mac computer and simply pull the digital info off of the disc (called DVD “ripping”) and convert it to a Quicktime file that can be edited in FCP.
    Here are some popular rippers.
    https://www.dvdxdv.com/
    https://www.miraizon.com/products/products.html
    Ihttps://www.mactheripper.org/
    MPEG SlipStream is very popular.
    Found at the following link>
    https://www.squared5.com/
    DVD footage in MUCH more severely compressed than DV, but. if it was recorded and compressed well, it should look very nice.
    You do want to avoid as many DV>DVD>DV>DVD conversions as you can.
  • Rennie Klymyk
    March 8, 2008 at 10:47 pm
    [Riccardo Vitale] “And, most important: Is there any loss of quality when going from MiniDV to DVD and back to MiniDV via firewire !? “
    Get the tapes. DVD is a final delivery format. You take a 20 GB project and encode it to a 4.7 GB file to squeeze it on to the dvd disc. This is intelligently done but the process is lossy, meaning data is lost in the process. Upon play back dvd decoders intelligently fill in the lost data with good enough accuracy to fool our eyes but if you plan to rework this video you will get some artifacts. DV isn’t the greatest but at least it is frame by frame resolution. You should always use original footage to edit or digital copies of original footage which it sounds like the mini dv tapes are.
    “everything is broken” ……Bob Dylan
  • Riccardo Vitale
    March 25, 2008 at 2:12 am
    Thank you much for your help.
    Riccardo Vitale PhD
  • Riccardo Vitale
    March 25, 2008 at 2:15 am
    Rennie, thank you for your answer !
    We managed to get the original MiniDvs and made copies.
    These were NTSC MiniDVs and we copied them using two cameras. To reproduce we used a small consumer NTSC Panasonic cam connected via firewire to a Sony PD170 PAL. It seemed to have worked fine. Do you think this is an ‘orthodox enough’ way to make the NTSC to PAL conversion?
    Cheers
    Riccardo V.
    Riccardo Vitale PhD
  • Rennie Klymyk
    March 25, 2008 at 6:05 am
    I want the model number of the panasonic camera you used for playback. If it played back NTSC DV through firewire and you recorded that stream to a PAL DV format and got a good looking PAL DV cassette from it I’m going to buy 100 of each camera to start with and mount them in a box with the cassette doors facing out to the front of the box and seal them in there connected with firewire. I will then sell these “boxes” as real time NTSC – PAL converters for $10,000.00 each.
    There is no way this should work. Try to play these “PAL” copies you made this way in the panasonic camera. If they are PAL they will not play but if they are still NTSC they will play. I think the Sony PD-170 PAL camera must have somehow recorded it to NTSC. Cameras can’t convert but possibly some can play and record both formats (like the Sony DSR-11 deck). I think your copies you made this way are still NTSC.
    If this is what has happened you can take your digital copies and convert with Nattress format converter for good results however this is a very slow process so you want to be very selective in how much you are going to convert.
    https://www.nattress.com/Products/standardsconversion/standardsconversion.htm
  • Riccardo Vitale
    March 29, 2008 at 6:27 pm
    Hi Rennie !
    Yes indeed ! I tested it and as you say the MiniDVs are in NTSC format. Now we are making a small demo of the doc and the material is in the hands of an editor. I suggested to him to convert formats using Nattress.
    Thank you so much for your help !
    Riccardo
    Riccardo Vitale PhD
