Activity Forums Apple Final Cut Pro Legacy DVD footage best workflow for using it in a HD sequence
  • DVD footage best workflow for using it in a HD sequence
    Posted by Joe Riggs on September 27, 2014 at 2:25 pm
    I have a project where the majority of the footage is 1080p 23.976 and I’m working in those sequence settings.
    I’ll need to combine some footage from a DVD into this sequence, the DVDs are standard definition and interlaced.
    What’s the best workflow (and programs) to get the footage off these DVD’s, de-interlace them, convert them to 23.976 and possibly
    scale them up using a plug in?
    I can work within Premiere if that would be beneficial instead of FCP7.
    Thank you
    Shane Ross replied 11 years, 12 months ago 2 Members · 1 Reply
  • Shane Ross
    September 28, 2014 at 12:08 am
    If you have premiere pro, best to use that. Not only can it access the DVD media without converting, but it up scales better than FCP. By a longshot. And also does frame rate mixing better.
    If you do need to rip, do the deinterlace when you rip. MPEG streamclip does this
    Shane
    Little Frog Post
