Activity › Forums › Adobe Premiere Pro › dvd encore prob
dvd encore prob
Posted by Rex Monga on August 25, 2009 at 5:57 amhi guys
i m rendering mpeg2 DVD in premier pro. but it gives me 2 file one is m2v video and .wav audionow can any one tell me how to link them so that i can play them
regards
rex monga
Jon Barrie replied 17 years ago 4 Members · 3 Replies -
Brian Louis
August 25, 2009 at 7:44 amWhat you have is Elementary Streams for importing into Encore for authoring, if you want muxed A/V you need to select Multiplexer under advanced settings in the Media Encoder.
Jon Geddes
August 25, 2009 at 3:15 pmAn m2v and wav file is just what you want for Encore. While in Encore, in the project window, import as timeline, then select both the wav and the m2v, then click open/import. It will create a timeline with both of them together.
Jon Geddes
http://www.precomposed.com -
Jon Barrie
August 26, 2009 at 11:02 amThere does seem to be a problem with Multiplexed MPEG-2 DVD files from CS4 when importing to Encore. So I would avoid it. Just do it with separated video and audio files.
The best part of having the video and audio separated is that if you need to re-export because of a video or audio only adjustment, you just export that part by unticking the audio or video from the output settings and the whole process doesn’t need to render the other = faster render times for re-renders based on adjustments.
– JB
Jon Barrie
aJBprods
http://www.jonbarrie.net
