Activity Forums DVD Authoring DVD duplication Glitch/Bitrate?
  • DVD duplication Glitch/Bitrate?
    Posted by Stephen Sarsfield on March 19, 2008 at 2:54 pm
    I was under the impression that DVD authoring bitrates over 7 can cause duplication problems, however, in the DVD studio Pro manual, it is recommended the bit rate be 9.
    We have been authoring DVDs here with VBR 4-6 kbs. What is the proper bit rate for duplication at 8x?
    Also, I have been told that if i dupe at a slower speed it may help the problem. any advice?
    George Wing replied 18 years, 5 months ago 2 Members · 1 Reply
  • George Wing
    March 19, 2008 at 10:01 pm
    Slower burn speeds *might* help (depends on how well your burners work with your blank discs — also using quality blanks helps in the long run).
    4-6mbps shouldn’t be causing any problems. How many audio tracks do you have, and what type of audio are you using?
    Regards,
    George
