Activity Forums Apple Final Cut Pro Legacy DVD Dub while Capturing in FCP?
  • DVD Dub while Capturing in FCP?
    Posted by Lisa Strong on May 9, 2007 at 1:16 am
    Moo —
    I’m shooting DV anamorphic and capturing each interview tape as one clip. Then I have to make a DVD dub of the footage to send to other team members. I’ve made the dubs thus far with a one-button menu, one-track in DVDSPro after I’ve captured. Compressing and burning, of course, take a good long time. I think I need an external DVD burner wherein I can just play the tape (or the timeline) and record in real time. Then I thought, what I really want is to be feeding the DVD recorder a signal to burn while at the same time capturing from my deck via firewire. It would save an hour each tape. Does anyone do this? What external DVD burner do you recommend? Would I have to worry about anamorphic coming out funny on the DVD, or is it flagged on the dv tape itself?
    Your suggestions and comments are much appreciated.
    LS-A
    Lisa Strong replied 19 years, 4 months ago 7 Members · 14 Replies
  • 14 Replies
  • Jerry Hofmann
    May 9, 2007 at 2:17 am
    The only burners that capture in RT are to DVD’s that are MPEG-2 I think… Is that what the other team members want?
    If so I suppose you could record the analog outs, but the TC wouldn’t match probably… you could send out a window burn of it too with the right deck. But it would be MPEG and not DV..
    Jerry
  • Lisa Strong
    May 9, 2007 at 2:44 am
    Jerry —
    No one else needs the actual DV files. They’re just keeping tabs on content, what folks are saying, so mpeg2 is what they need. Precise timecode probably isn’t necessary either. It just needs to be close enough that I can fairly easily find a story or anecdote someone is telling.
    So are you thinking just, deck to computer via FW for capture; simultaneously, analog out from deck (which now goes to the monitor on the deck), to an analog in of a DVD burner?
    Is there such a thing as a firewire splitter so one split goes to FCP and the other goes to the DVD burner out from the FW deck?
    LS-A
  • Ernie Santella
    May 9, 2007 at 3:22 am
    If your deck has both Firewire out and analog outs and you are capturing to FCP with FW, then you can feed the analog outs to a standalone DVD recorder. I have one and it’s great for quick dubs or reference window burns. It records in real-time straight to DVD.
    Ernie Santella
    Santella Film/Video Productions
    http://www.santellaproductions.com
  • Lisa Strong
    May 9, 2007 at 3:46 am
    I wouldn’t be able to watch/listen to the footage on the monitor, but I could still see it in the capture window, so I think I could do that.
    What model/brand of DVD external burner do you use? Are you happy with it? Would you replace it with the same thing today?
    LS-A
  • Bob Flood
    May 9, 2007 at 1:48 pm
    Lisa
    2 things
    1. great idea, use the composite video and analog audio out of a decent dv deck to feed a dvd recorder (we use a model called Lite On) the analog outs may even letterbox the stuff
    most decks can display the “User info” and better decks will give you a window burn.
    the caveat is if fcp chokes while capturing, you will have to make a couple of chapters on the dvd, stopping one where it choked and resuming on the next.
    2. actually mentioned in one, we use a dvd recorder called a “lite on”. consumer grade, variable capacity (6 hours max). and the ability to stop and start before finalizing.
    hope this helps
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
  • Ernie Santella
    May 9, 2007 at 2:13 pm
    I use an older Panasonic E80H. It also has a built-in HD, so you can archive to that and make multiple dubs later. There’s plenty of DVD burners from Panny and other companies.
    Ernie Santella
  • Chris Poisson
    May 9, 2007 at 2:18 pm
    Lisa,
    I don’t know about the anamorphic issue, but the DVD recorder is a great idea, I have an off-brand made by LG called Insignia which I got at Best Buy for 180 bucks, it also has a vhs player, and ALL of it plays through component out, plus it has Firewire in. This deck is so cool, it can record perfect DVDs from off-speed MiniDVs and even controls the camcorder feeding in. I’m sure you would not go wron with any DVD recorder with Firewire in, however FW will likely not work while FCP is capturing. The advice above for analog probably would.
  • Jeff Carpenter
    May 9, 2007 at 3:35 pm
    You’ve got a much easier solution at hand, Lisa.
    You have a Mac. You have a DVD burner. Do you have iDVD version 6? (If not, it’s $80 to upgrade iLife.)
    Once you have those elements, you’re all set! See here:
    https://www.apple.com/ilife/idvd/features/onestepdvd.html
    I’m not sure how to handle the anamorphic, but I know iDVD does do widescreen DVDs. I’m sure a little experimenting is all it will take.
  • Chris Poisson
    May 9, 2007 at 4:43 pm
    Jeff,
    If I read correctly, she wants to make the DVD at the same time she’s capturing the footage. How can she do that with iDVD?
  • Lisa Strong
    May 9, 2007 at 4:52 pm
    I saw a review for the Panasonic DMR-T3040 DVD Video Recorder on Ken Stone
