Activity › Forums › VEGAS Pro › DVD creation & menu
  • DVD creation & menu
    Posted by Rick Hughes on July 19, 2015 at 7:23 pm
    I have been having great help in a separate thread on a 35mm slide to DVD project.
    Raising this as separate question as related to the DVD burn.
    After rendering I will end up with several .mpg files (or m2V files for Blu-ray discs) each in the area of in region of 10mins long (typical box of slides)
    2 things here
    It would be nice to have a menu front end so you can choose the slide set (which may be a holiday or family event) … but also would like an autoplay feature, so if put into a DVD player – if menu options not chosen it will autoplay through all in sequence.
    I will be using MSP 12 and DVD Architect Studio 5
    Welcome any advice over neatest way to do this ……….. only ever created single file DVD, not used menus before.
    David Eon replied 11 years, 2 months ago 4 Members · 3 Replies
  • John Rofrano
    July 19, 2015 at 10:47 pm
    DVD Architect Studio 5 will allow you to author a DVD with menus just like you want. Just start a new project, select a theme, and drop your footage onto the menu. The only thing you might not be able to do is have it auto-play if no one presses a menu selection. That feature might only be in DVD Architect Pro via DVD Scripting. Other than that, you should be fine with the Studio version.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    July 20, 2015 at 5:09 am
    I use ConcertXtoDVD more often, Has all the bells and whistles included,
    easy to use, powerful and never produces a bad disc.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • David Eon
    July 21, 2015 at 1:25 am
    In DVD Architect, you can set the End Action for the menu to Auto-play on the right side by choosing End Action> Command> Activate Button then change Timeout to the however long you want the menu to show before the Auto-play starts. You can change which button will activate as well. Let me know if this helps. Thanks!
    DavidEon
