Activity › Forums › Apple Final Cut Pro Legacy › DVD created with iDVD from Blackmagic 8bit timeline, picture tears with fast motion
Daniel Fiorito replied 20 years, 7 months ago 8 Members · 16 Replies
Walter Biscardi
July 27, 2005 at 3:14 pm[isoprophlex] “IDVD is perfect though for laying off rough cuts fast.”
Actually, the easiest way to lay off a rough cut for a client or producer is to use a DVD Recorder. I have the Philips DVDR-75 which takes a feed directly out of my system. Just hit play in FCP and hit Record on the DVD Recorder.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Alexander Serpico
July 27, 2005 at 3:21 pmConsidered it, and i do have one. Didn’t feel like getting one for every single edit room at this point, considering iDVD is supposed to work.
Mark Maness
July 27, 2005 at 8:40 pmWalter…
Let ask you, how do you export to DVDSP using MPEG-2 in FCP 5? I have Final Cut Studio and I haven’t found an option to export in MPEG-2 for DVD.
_______________________________
Wayne Carey
Schazam Productions -
Alexander Serpico
July 28, 2005 at 3:54 pmThis option magically disappeared a number of os/fcp revisions ago. We do a direct Export > Quicktime Movie, then let idvd or dvdsp do the conversion for us.
This field issue seems to be a FCP problem over iDVD or DVDSP, since it is widespread:
There is a thread in the DVDSP forum –
https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=155&postid=855217&pview=t#head -
Macafilm
August 5, 2005 at 4:58 pmI’ve had this annoying problem for awhile now. I’m using Blackmagic HD pro and we’ve worked with
idvd and dvdstudio pro for a long time. We did a show for the paris air show and we couldn’t understand why on some of the fast movement the video looked like crap. I actually saw a local tv ad the other day
on tv that visibly had the same problem. Your breaking my balls apple. Get your sh*t together.Forced to work on FCP
mark
Daniel Fiorito
January 24, 2006 at 12:01 amHi there,
I read your post from last August – you had a problem with an error message iDVD gave you about incompatible format while trying to burn a dvd. You said you exported a quicktime movie from a FCP 5 project and tried to burn it on iDVD 5.0.1.
This is the error message you got:Error: The recording device reported the not ready error. Cannot write medium-incompatible format (0x30, 0x05)
I’ve tried to burn the quicktime movie I exported from FCP 4.5 but I get the same error message you got. were you able to resolve the issue? what did you do differently?
the weird thing for me is that last month I exported this very same FCP project as a quicktime movie and burned 10 copies using idvd. Unfortunately all 10 copies of the dvd skip pretty badly…so I don’t know what’s going on!
Any help you can give would be great!
thanks,
daniel
