Activity Forums Apple Final Cut Pro Legacy DVD convert to QT…compresson question
  • DVD convert to QT…compresson question
    Posted by Andy Levine on March 1, 2006 at 2:40 pm
    quick question:
    when I convert a dvd file with mpeg streamclip for use in FCP what compression should I chosse, what should I choose for sound?
    Right now i am using mpeg4 and need to render each file I convert once it is in FCP. I know there is a better way.
    Thanks.
    -Andy
    Andy Levine replied 20 years, 6 months ago 2 Members · 2 Replies
  • Shawn6432
    March 1, 2006 at 5:20 pm
    You should export as what ever format you are using in your FCP sequence. If you are using the DV codec in FCP then you should export from mpeg streamclip as DV.
    You should be aware that DVDs use very highly compressed video. If you take that, edit it and then re-compress back to DVD there will be a noticeable loss in quality.
  • Andy Levine
    March 1, 2006 at 5:34 pm
    thanks for your advice…
    I am using dv ntsc 48khz – I export movie from dvd as dv ntsc and still when I open it in FCP it appears unrendered…
    what about the sound settings?
