Activity › Forums › Compression Techniques › DVD Compression
DVD Compression
Posted by Bill Hamilton on September 26, 2006 at 11:39 amI am looking for DVD compression software that allows setting of the GOP structure. I am trying to go for very high quality video (as high as possible) on standard DVD. Any suggestions?
BillCharles Simonson replied 19 years, 12 months ago 3 Members · 5 Replies -
Ed Dooley
September 26, 2006 at 2:14 pmMy first suggestion is, tell us what platform you’re on, or want to be on. 🙂
And do you have an authoring program already, or do you want a recommendation for that too?
Ed[Bill Hamilton] “I am looking for DVD compression software that allows setting of the GOP structure. I am trying to go for very high quality video (as high as possible) on standard DVD. Any suggestions?”
Bill Hamilton
September 26, 2006 at 2:34 pmI am on Windows, but I may be able to use Mac as well. I ideally would like to compress I frame only. I hope to keep authoring to a minimum.
Basically here is what I am trying to do. We have several video clips used for demonstration purposes in a traveling system. We are currently using a Leitch server with 50Mb/s and I frame only compression (this is probably better than I can get on DVD). The server is overkill, hard to operate for our configuration and not reliable on the road. We are looking into using DVD if the quality can approach what we are using now.
Bill
Ed Dooley
September 26, 2006 at 2:38 pmBTW, a lot of MPEG-2 encoders allow you to play with the GOP. Procoder on PC is great, as is Main Concept.
I use Compressor and Bitvice on Mac, and although I prefer Bitvice, it doesn’t allow any GOP settings except
Open or Closed. Compressor allows tweaking.
Ed -
Ed Dooley
September 26, 2006 at 2:59 pmNow you’re getting out of my comfort zone. As for your bit-rate though, there are a number of broadcast
MPEG-2 encoders (I know Grass Valley makes one) that will compress to over 50Mb for broadcast. I don’t
know about their I-frame-only encoding, but for very high bit-rate, you might look at broadcast encoders.
Procoder and Main Concept will also compress to very high bit-rates.
Ed -
Charles Simonson
September 27, 2006 at 12:56 amFirst, DVD doesn’t support an all I-frame mode. You can store an all I-frame encode on a disc, but it must be used only as a file, not as a disc that is compatible in STBs. Second, the recommendations of MainConcept and ProCoder are highly backed.
