Activity Forums VEGAS Pro DVD capacity/settings for HD in DVD Architect 5.2
  • DVD capacity/settings for HD in DVD Architect 5.2
    Posted by Dan Myers on December 31, 2012 at 7:26 pm
    HI,
    I am now making a DVD for a wedding I did in HD. This is the first time I will be doing a full length project. The total length is about 2 hours and 20 minutes. I have split the file into two parts around 1 hour and 10 minutes each. This is basically the same thing I did with SD. The difference is now I’m not sure how much of the HD I can get on a 4.7 GB DVD. I am using MPEG 2 with the HD 60i setting.
    The custom setting is 25,000,000 vs. 8,000,000 for SD. Do I need to set up custom bit rates each time based on the length of the video as I did with SD? If so, is there a bit rate calculator that will do this for HD and will trying to get this onto two DVD’s (part 1 and 2) work?
    Please advise.
    Thanks.
    Dan.
    John Rofrano replied 13 years, 8 months ago 2 Members · 2 Replies
  • Dan Myers
    December 31, 2012 at 7:27 pm
    Also…I’m using Vegas 10
  • John Rofrano
    January 1, 2013 at 3:13 pm
    [Dan Myers] “The difference is now I’m not sure how much of the HD I can get on a 4.7 GB DVD. I am using MPEG 2 with the HD 60i setting.”
    About 20 minutes! Why would you use a DVD for HD content? You should be burning Blu-ray discs if you want HD. Especially if you are giving this to someone else.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
