Activity › Forums › VEGAS Pro › DVD Camcorder import function not importing audio
  • DVD Camcorder import function not importing audio
    Posted by David Oddleifson on December 29, 2009 at 3:16 pm
    When I import a non-copyrighted DVD using the import function for DVD Camcorder under the file menu, I am able to extract the video but not the audio. Do I need to specify somewhere that I want to extract the audio as well?
    Thank you
    John Rofrano replied 16 years, 9 months ago 3 Members · 5 Replies
  • Joe Mantaratz
    December 29, 2009 at 5:16 pm
    If you are using the “import camcorder disc” function there is no further step for audio. The video files cannot just be copied into Vegas as it will truncate the files. Not sure why you would not be getting audio. Is this from a camcorder disc or from a burned DVD? Some camcorders use 4 channels and as I recall Vegas only sees 2. That might be the issue if it is from your camcorder. A little more details might help.
  • David Oddleifson
    December 29, 2009 at 5:54 pm
    Thank you for your response.
    The DVDs are burned DVDs but they have worked in the past. We had to re-build our operating system and after we re-installed Vegas, this problem pops up. The strange part is that when I play the imported files in windows media player, the audio works correctly. However, when I import them into Vegas, the audio does not appear. The DVDs shouldn’t have 4 channel audio because they were made from 2-channel media.
  • Joe Mantaratz
    December 29, 2009 at 8:21 pm
    Understand…then try this. Explore the DVD, copy it to the desktop, change the extension to MPG instead of VOB and drag the file to the timeline. The audio should be there but the video will be shortened. This is just a test.
    There is no reason I can see why the audio would not be seen in Vegas and yet play in Media player. How were the DVD’S burned? Since you mentioned they worked before what were you referring to?
  • David Oddleifson
    December 30, 2009 at 3:37 pm
    Thanks for your responses. I ended up calling Sony. Turns out that there is a known issue with 9.0a not importing the audio off of mpeg2’s. The fix: updating to 9.0b. Something I should have thought of but didn’t after we reinstalled the program.
  • John Rofrano
    December 30, 2009 at 5:46 pm
    When you re-installed Vegas did you also re-install DVD Architect? The AC3 codec is shipped with DVD Architect, not Vegas.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
