Activity Forums Apple Final Cut Pro Legacy DVD Burning work flow
  • DVD Burning work flow
    Posted by Michael Noble on October 17, 2006 at 9:47 pm
    I shot HDV 1080i 60. I cut on a new sequence setting matching that easy setup. It is shot 16:9 on the camera. I have had problems before where I have the text in the letter safe zone and then when I burn and play the DVD on some tvs it cuts off letters.
    So I make a QT file using the HDV 1080i setting.
    Then I compress it in compressor.
    Then I goto DVD Studio and make a straigh DVD burn.
    What am I not setting properly?
    Mike
    Chris Poisson replied 19 years, 11 months ago 2 Members · 1 Reply
  • Chris Poisson
    October 18, 2006 at 4:07 am
    Mike,
    You can go direct to Compressor from your FCP timeline. Your settings in DVDSP should be 16×9. Check in the inspector. You need to set your men up that way too and your simulator if you use that.
