Activity Forums Apple Final Cut Pro Legacy DVD burning weirdness – crosspost
  • DVD burning weirdness – crosspost
    Posted by Mo Gardner on December 7, 2005 at 11:31 pm
    I also have this up in our local forum.
    I can’t get a flawless DVD burned out of my system. Any video motion happening at a transition creates this wacky “venetian blind” looking garbage which is not present in the reference file. So, is the the type of file I’m using? Could my SuperDrive be on the fritz?
    ps. I’ve taken it to different DVD players and get the same playback results. Also, the “venetian blind” looking garbage is appearing during almost all video motion. Hmmm…
    I’d appreciate any input.
    … ever forward
    … ever forward
    Mo Gardner replied 20 years, 9 months ago 3 Members · 4 Replies
  • David Roth weiss
    December 8, 2005 at 4:06 am
    Mo,
    This problem happens more with some encoders than others, and with some authoring programs more than others, and especially so if the authoring program is, unbeknown to the user, re-encoding the material. There are many ways of creating DVDs with FCP, and you haven’t mentioned what software you’re using for encoding and authoring, or the bitrate of your MPEG2 encode — these are essential if you want to get an informed answer to your question.
    DRW
  • Mo Gardner
    December 8, 2005 at 10:20 am
    Compressor is not working for me right now, so I just export a fully rendered reference file from FCP. I’m burning with iDVD at “Best Quality” setting. If I play the file (before burning) it’s all fine and dandy, but the burned disk displays the problems I’ve mentioned.
  • Rich Rubasch
    December 8, 2005 at 2:54 pm
    Is your sequence 486? It sounds almost like a field order problem. If you are sending a 486 clip to iDVD it might just crop 3 tip and 3 bottom, or worse, scale down the 6 lines to 480 which will cause the problem you describe. It doesn’t sound like compression artifacts, but field order to me.
    Rich Rubasch
    Tilt Media
  • Mo Gardner
    December 8, 2005 at 2:56 pm
    … of my startup disk, that is. May fix some other issues too, I’m told.
    Thanks for the responses.
