Activity Forums Adobe Encore DVD DVD burning question
  • DVD burning question
    Posted by Kevin Camin on January 24, 2014 at 10:22 pm
    I’m burning 1080i footage to DVDs with Encore. When it transcodes it down to 720×540 or whatever, will it screw up the fields and create a weird looking picture?. I ask because, if I need to resize interlaced footage, my normal workflow is to do a deinterlacing pass first, then do the resizing pass, otherwise it gets screwed up if you just try to resize interlaced footage.
    Best regards,
    Kevin Camin
    Daniel Ludwig replied 12 years, 7 months ago 2 Members · 3 Replies
  • Daniel Ludwig
    January 26, 2014 at 4:16 pm
    Kevin,
    as long your transcoding-setting fits to the source, everything will be fine.
    1080i is upper field first, ntsc normaly is lower first, but in your case you need to take care that your SD-transcoding-setting is upper field, too.
    cheers
    danny
  • Kevin Camin
    January 26, 2014 at 10:29 pm
    Thanks. But if I encode a DVD with upper fields first in the US rather than lower fields won’t hat playback janky on a DVD player?
    Best regards,
    Kevin Camin
  • Daniel Ludwig
    January 26, 2014 at 10:33 pm
    NO – important is to use same field-order as the source-material.
    danny
