Activity › Forums › Adobe Premiere Pro › DVD Burning in PP7
  • DVD Burning in PP7
    Posted by Peter35 on September 23, 2007 at 7:31 pm
    As a “rooky” in PP7 I managed to make a long movie and want to burn it to dvd. How much can I burn on a dvd? Does PP give a warning if more dvd’s are required?
    The film is 2 hrs and (even after cleaning) I have more then 35 GB space left. Is this space needed for rendering?
    Thanks.
    Peter
    Peter35 replied 19 years ago 2 Members · 2 Replies
  • Mike Velte
    September 24, 2007 at 1:31 pm
    You can burn 2 hours to a DVD, but the quality is going to be poor, especially if all you have is Premiere and not Encore (for Dolby audio). You will need to set the video bitrate to 3100 kbps to allow 2 hours of video and PCM audio to fit.
    If your content is action packed, your best bet is to use 2 DVDs with a video bitrate of 6000 kbps.
    You will chew through about half of your disc space creating temp files in the process.
  • Peter35
    September 26, 2007 at 8:18 pm
    Thx.
    I did as suggested and no problems with the burning process.
    Re.
    Peter
