Activity Forums DVD Authoring dvd burner error
  • dvd burner error
    Posted by Graeme on April 30, 2005 at 10:48 am
    I have a sony dw22a + and – r 4x burner and in device manganger all is well but when i try and burn to dvd from roxio or encore:
    roxio says power calibration error 03/73/03
    and encore says the same
    yes im using tdk disks and writing at 1x speed
    seems like its the burner that is the problem but its new
    any ideas
    graeme
    Graeme replied 21 years, 4 months ago 2 Members · 4 Replies
  • Roadkill
    April 30, 2005 at 4:27 pm
    Even though the burner is new, it could be a dud…
    Before returning it, some things you could test:
    • Try a different brand DVD-R (e.g. Maxell or Verbatim).
    • Make sure that the burner is connected as “master” on the IDE channel it is connected to and check if the jumper on the burner (and that of any other device connected to the same channel) is set correctly.
    • Check if the IDE cable is seated properly on both ends. Try another cable if you got one.
    • Check and if necessary update the ASPI driver on your system to v4.70 or higher (Windows ASPI Package Downloads).
    • Change the DMA/PIO setting for the burner (in Device Manager). If it is on DMA, change it to PIO and vice versa.
  • Graeme
    May 1, 2005 at 11:07 pm
    cant find in device manager where the control from DMA is?
  • Roadkill
    May 1, 2005 at 11:37 pm
    Enabling DMA in Windows XP
    1. Log onto Windows as Administrator (or as a user with Administrator privileges).
    2. Click the Start button, then right-click on My Computer and choose Properties from the pop-up menu.
    3. Click the Hardware tab, then click Device Manager.
    4. Double-click IDE ATA/ATAPI controllers to see the list of controllers.
    5. Double-click Primary or Secondary IDE Channel (the one your burner is connected to).
    6. Click the Advanced Settings tab.
    7. Choose DMA if available from the Transfer Mode list.
    8. Click OK. You do not need to restart Windows.
  • Graeme
    May 1, 2005 at 11:42 pm
    the dvd burner is not under ATA/….
    its in the list underdvd/cd devices
    and when you bring up properties there is no advance tab
