Activity Forums Apple Final Cut Pro Legacy DVD burned video bad
  • DVD burned video bad
    Posted by Randy Rohde on May 20, 2005 at 7:03 pm
    My finished timeline video looks fine. I export a QT that FCP turnes into a seq. I burn the file with iDVD all is well BUT the video is artifacting – jagged edges on video with any movement. I’ve done this in the past 4 times and all worked well. I ALSO tried burning a QT uncompressed (BetaCam 8bit) file same results.
    Chris Poisson replied 21 years, 4 months ago 3 Members · 4 Replies
  • Chris Poisson
    May 20, 2005 at 7:13 pm
    Hey Randy,
    What kind of footage? How shot? Could be a field order issue or pulldown if you shot film.
    Hey, I looked at your profile, you’re a neighbor, I live over by the Pointe at South Mountain.
  • Randy Rohde
    May 20, 2005 at 7:21 pm
    Shot BetaCam SP inported uncompressed and exported to QT uncompressed then burned. The stange thing is this is my 5th project on FCP all the past ones look great. What do you do at the point? I am shooter editor and bottle washer for Word of Grace church. We produce a video a week for the main service here and just got the FCP system
  • Sandy Imhoff
    May 20, 2005 at 10:40 pm
    I had the same problem last weekend burning a sample video to IDVD.
    It was working well a few weeks ago but now IDVD seems to be squishing
    the footage vertically. There is a black bar on the top and bottom of the screen
    and the fields are totally mangled. I was using 10bit footage.
    I then tried other SD footage on my machine that was in a variety of
    codecs; 8bit, pjpeg etc and also footage that was 486 high and 480 high.
    Some of the footage was made in FCP some in After Effects. I had the same
    results with everything that I tried. I then tried DV footage and that worked as it should.
    -Sandy
  • Chris Poisson
    May 20, 2005 at 11:04 pm
    Hmmm,
    Sorry, I don’t use iDVD, so I can’t help.
    Randy,
    I just live NEAR the Pointe @ SM, I’m a video production/editorial provider, if you check my profile it will give you a link to my URL
