Activity › Forums › Adobe Encore DVD › DVD build not working, but Flash build is?
  • DVD build not working, but Flash build is?
    Posted by Daniel Bacchiocchi on December 18, 2010 at 3:14 am
    I created a dvd in Encore CS5. The dvd previews fine and i can build a working Flash version. However when i create an image or disc “DVD” it will not start and says “Application not found”
    I have a menu set as first play, is that ok?
    Dvd goes like this:
    Disc-> Menu 1
    chapter 1 ——————>Menu 2 —slideshow
    chapter 2 ——————>Menu 3 —slideshow
    chapter 3 ——————>Video 1
    I set first play to Menu 1. In the same properties the “main timeline” is video 1. I checked for project errors with “check project” but did there were none.
    If it previews fine and builds flash fine shouldn’t it burn or image fine too?
    Daniel Bacchiocchi replied 15 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
