Activity › Forums › DVD Authoring › DVD- BAD INTERLACING COMING FROM 1080i
Posted by Mia Maffioli on June 26, 2012 at 1:52 pmHello
I am authoring a DVD of a film that has been shot 1080i.
While I do understand the quality loss going from HD to SD, the DVD shows a HORRIBLE interlacing, especially on camera or characters movement.
When I say HORRIBLE I mean UNACCEPTABLE.
I tried authoring the DVD with Compressor using the highest quality possible, but to no avail.
Can anyone help?
Many thanksMichael Slowe replied 14 years, 3 months ago 6 Members · 7 Replies -
Juan Manuel
June 26, 2012 at 2:08 pmHave you tried removing a field? You have resolution to spare, at least for the dvd
Mia Maffioli
June 26, 2012 at 2:11 pmHow do you do that?
I work on a Mac, with Final Cut Studio.
Many thanks -
Juan Manuel
June 26, 2012 at 2:55 pmIf you’re exporting through Compressor, there is a de-interlace filter in the filters tab in the inspector. Just select odd or even in the algorithm drop down and it will remove one of the fields. You could also try the slower, but better, de-interlace option in frames control as well. That doesn’t remove fields but interpolates them.
Eric Pautsch
June 26, 2012 at 5:10 pmNo! You never want to deinterlace since DVD is natively an interlaced format. Deinterlacing wipes away half your temporal info.
Have you the field dominance correct?
Michael Sacci
June 26, 2012 at 9:18 pm1080i is upper field. Just change your field dominance to upper for the m2v and all will be good. Yeah 30p will almost always get output as 60i to the tv.
Also most people find that you get better quality if you down convert to sd pro res and then do the m2v pass. But remember to keep it upper frame first.
Noah Kadner
June 28, 2012 at 10:46 pmNope- do not remove a field that’s halving your resolution. Lemme guess- you went directly from 1080i to MPEG-2? That’s not the best way to do it, because downconversion and encoding at the same time=low quality. Instead- output a standard definition 16:9 version of your 1080i timeline first to ProRes. Then use that as an MPEG-2 source for your DVD. Guarantee it will come out great…
Noah
Call Box Training.
Featuring the Panasonic GH2 and Panasonic AC160/130. -
Michael Slowe
July 4, 2012 at 10:46 amNoah, I agree that the initial down conversion is key but how are you doing it? I let BitVice do that as well as the encode which you say is not good. I get first class results on my DVD’s with this method. I edit in Media 100 and their downscale is not the best. I’m cutting in ProRes 422 HQ and the original is shot on Sony EX XDCAM 1920 X 1080i.
Michael Slowe
