Activity Forums DVD Authoring DVD Authoring Workflow
  • DVD Authoring Workflow
    Posted by Scott Irwin on December 7, 2007 at 5:01 pm
    Just curious if anyone has a specific workflow that they think works really well for outputing to DVD. I’m using mostly After Effects for motion graphics and am looking for a good, cost effective solution for getting work to dvd, ie. AE to Sorenson Squeeze to DVD-lab. Does anyone have software they’re particularly fond of?
    Murphy Thelen replied 12 years, 1 month ago 3 Members · 2 Replies
  • Alessio Gemma
    December 9, 2007 at 8:25 pm
    Hi, in AE I always export in uncompressed or high bit rate codec. Now, I use the last Apple ProRes Codec, but before I used to export in Animation codec: ProRes has the same quality of Animation but at lower bit rates (smaller exported files)
    Then, I use Compressor (but you can use Squeeze or something like that) to obtain the MPEG2 for your DVDs.
    Regards,
    Alessio
  • Murphy Thelen
    July 28, 2014 at 7:43 pm
    AE CS6–>Output ProRes 422(HQ)–> Encore CS6–> Output ISO–> Burn ISO to disk using Toast and Blu-ray burner (even if authoring an SD dvd).
    Works like a charm.
