Activity Forums DVD Authoring dvd authoring process
  • dvd authoring process
    Posted by Curtis Doss on May 5, 2005 at 11:12 pm
    Could someone direct me to some information about the entire process of making an encripted glass master and duplicating dvds from the time I have authored it in DVD Studio pro. Mainly I would like to know the significance of the DLT and macrovision, and to know if making a dlt is the only way to apply macrovision.
    Thanks for your help
    Roadkill replied 21 years, 4 months ago 8 Members · 7 Replies
  • 7 Replies
  • Michael Autery
    May 6, 2005 at 6:10 am
    Glass Mastering comprises a number of stages needed to create a metalized glass master from which the stampers are produced for the DVDs to be stamped/replicated
    Encryption CSS/Marcovision is done at the replication facility when making the Glass-master, depending on the replication facility you may be able to send your DVD-r master to the replicator and have them add the CSS/Marco-vision when creating the glass-master
    Duplication is done with a CD/VD duplicator which you can purchase for a couple grand, you buy blank media and burn the Disc your self or have someone else do it for you
    Replication is the process of making a glass-master, Stamper and the DVDs are manufactured and not burnt to blank media.
    maybe that helps
    Regards,
    Michael Autery
    DVD-Makers.com
    200 Encore Motion DVD Menus &
    260 DVD Motion Menu Backgrounds
  • Matt
    May 6, 2005 at 1:06 pm
    I’ve been told that the DLT will ensure that your DVD will play in all DVD players. If you just duplicate or replicate DVD-R or DVD+R you take the chance of your DVD not playing in some players. I had this problem once. I duplicated 300 copies of a DVD-R, and the discs wont play in high end sony DVD players, they play fine everywhere else though. I now do DLT everytime.
  • Bill Stephan
    May 6, 2005 at 8:01 pm
    The data is written to a DVD-R disc using 2048 byte sectors. If a DVD is to have Macrovision, CSS or region coding, a 2054 byte sector is required. These sectors cannot be written to a normal DVD-R, so the only way to create that formatting and get the data to the replicator is via DLT tape.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Mark Shueard
    May 8, 2005 at 10:03 am
    OR DVD-R for Authoring disks.
    Canopus/SONY Reseller Australia
    https://www.on2dvd.com.au
  • Fabrizio Roscini
    May 12, 2005 at 9:03 pm
    Hello, I’m really interested in this matter…
    Does anybody know if DVD authoring discs are available in double layer format?
    Fabrizio
  • Erick
    May 14, 2005 at 4:57 am
    Is there any way to copy protect a DVD-R ?
  • Roadkill
    May 14, 2005 at 12:39 pm
    Not really. The only “sort of” copy protection for writable DVDs is to burn your project to a DVD-RW that supports CPRM (Content Protection for Recordable Media) and burn DVD-R copies from this DVD-RW master. This seems to make copying a bit harder.
    Also see the DVD Demystified FAQ: What are the copy protection issues?
