Activity › Forums › DVD Authoring › DVD Authoring DVDLab Pro2
  • DVD Authoring DVDLab Pro2
    Posted by Rocio Aranda on August 28, 2012 at 2:40 pm
    Hello everyone!
    My apologize in advance because my English.
    I hope that my explication is clear.
    I need advanced help with DVDLab Pro2. So I hope to find any solution thanks to your suggestions.
    I am working in a project with two movies and I need to block each movie and each chapter through a keypad.
    The structure is:
    Main menu with both two movies so to watch them first the viewer needs to enter an access code (keypad).
    Also from each movie (it has 5 chapters) it’s necessary an access code to play each chapter.
    So, could anyone, please, help me to find a solution for it?
    Thank you.
    Regards.
    Rocio Aranda
    Rocio Aranda replied 14 years, 1 month ago 2 Members · 2 Replies
  • Eric Pautsch
    August 28, 2012 at 9:41 pm
  • Rocio Aranda
    August 29, 2012 at 3:26 pm
    New doubt!
    What can I do?
    I imported a .box component with my keypad. Now I need to open it to change the access code. When I try to open the menu to appear a window: ” Failed to create empty document”.
    I don’t understand because with the others Keypads I don’t have any problem.
    Any suggestion?
    Thank you in advance!
    Regards
