Activity Forums DVD Authoring DVD Authoring 101
  • DVD Authoring 101
    Posted by Russ Kiel on October 8, 2011 at 6:35 pm
    Hi, I’m new to the entire process of authoring & duplicating DVD’s and was hoping to get some advice.
    I’ve finished an HD short film project that’s exported at about 10GB (too big for a DVD) and am wondering what the best options are for compressing for DVD viewing? At the moment it’s a .mov, straight out of FCP.
    Although I have other compressed editions I was hoping to get the nicest possible output for submitting to festivals.
    I have DVD studio pro & could get access to Compressor if this helps, although my personal copy of compressor has never installed properly…
    I also don’t know the first thing about authoring the DVD.
    I’ve got a budget of $zero but would be willing to scrape some money together if absolutely necessary
    If you could point to the best tutorials for all the aspects I’d appreciate it.
    I need to get at least a few decent qualities ones together asap however, and then I can focus on producing better quality DVD’s for further distribution.
    I appreciate it, this site’s been helpful before, although this is my first post.
    Daniel Ludwig replied 14 years, 11 months ago 3 Members · 2 Replies
  • Michael Slowe
    October 9, 2011 at 10:24 am
    I have no doubts personally that you would do any better than to use BitVIce for your encoding of your DVD. I use it all the time and the new version has a great downscale capability as well. I merely drag my ProRes HQ 422 QT .Mov file into BitVice and it does the rest -wonderful. It does the audio at the same time.
    Michael Slowe
  • Daniel Ludwig
    October 9, 2011 at 8:09 pm
    Russ,
    the real first thing you need to know is to make a bitbudgeting before you start encoding your assets.
    NEVER use quicktime-movies within DVD Studio, and also don´t try to edit with any DVD authoring-suite. It´s not an editing-suite.
    DVD+/-R media couldn´t give you the full bandwith that DVD-specs allow, you need to have a max. bitrate at peak-rates of 8.5Mbit/s (video and audio).
    replicated DVDs could have up to 10MBit/s.
    allways use MPEG2 and dolby AC3 or maybe DTS audio. nearly 80% of all failed DVDs that I´ve seen dependending on uncompressed (PCM) audio.
    make sure that you allways using a track as a firstplay-item and not to go to menu.
    that´s for now – you will find more help on the DVD Studio Forum.
    cheers
    danny
