Activity Forums DVD Authoring DVD audio problem
  • DVD audio problem
    Posted by Cameron on June 12, 2005 at 1:10 am
    I started with an mp3 imported into after effects, then through dvd studio pro to make the dvd.
    the sound on my dvd is “crackly” sounding, with a pop every couple of seconds.
    i’m sure i just have to import it into after effects as a different file type instead of mp3.
    which file should i import into after effects?
    thanks!!!!
    cameron
    Roadkill replied 21 years, 3 months ago 2 Members · 1 Reply
  • Roadkill
    June 12, 2005 at 10:31 am
    I would suggest PCM (AIFF) audio, 48KHz, 16 bit. Also keep the maximum level below -6dB.
